19 years agomicroC/OS-II and 'thread safe c library' option
Marking the 'thread safe c library' in ´RTOS Options´ when using microC/OS-II affects the performance. How does marking ´thread safe c library´ affect my system? Is there a reason fo...
19 years agoThis is the answer I got from Altera:
Since "thread safe c library" will handle the synchronization of multi tasks to protect the shared resource, the performance will be lower than non thread safe c library. If you do not need any operation to protect the shared resource or there isn't any shared resource existed in your application, you do not need to choose thread safe c library option. My next question is: But if I use the mutexes or semaphores provided by microC/OS-II for protecting shared resources, then why should I use ´thread safe C library´? Anyone got a comment? /S
