16 years agoMEMORY TEST program usage
Hi guys, I need to test DDR on my board. I've created SOPC builder project with Nios and 2 memories - on-chip and DDR controller. Both reset and exceptions point to on_chip. Altera provides ...
15 years ago --- Quote Start --- If you use Nios EDS version 9.1 or higher you need to right-click on the BSP uin the Project Explorer, select Properties-> Nios II BSP Properties and select Reduced Device Drivers check-box, unselect Support C++ checkbox and select use small C library check-box. And select optimization level to SIZE in the Optimization level field. --- Quote End --- Thank you, it works!
