16 years agoMemory map in SOPC builder
Hi there, If I have two custom components in SOPC builder with memory mapped as the following: component 1: base=0x00000020; end=0x0000003f. component 2: base=0x00000040; end=0x0000005f....
16 years agoyou should only have to give your custom component a 7 bit bus for the address.
take a look at page 4 which shows that SOPC Builder will do a lot of the work for you in the fabric: http://www.altera.com/literature/hb/qts/qts_qii54003.pdf
