19 years agoMemory Initialization File
Hi everyone, I have a module containing a memory created by MegaFunction and mif-specified. But when i run , i see that my memory hasn't been initialized (using SignalTap). Maybe i didn'...
19 years agoI list mine along with the hdl source files. They show up in the others file list of the project. The Megafunction also has the file name embedded. The hdl/mif/hex files are all listed in the qsf. Careful about case. I was getting Quartus crashes with internal fault that was traced to case sensitive file name comparison and I hadn't kept the case usage consistent. Perhaps it has been corrected in the newer releases. This crash was only when the mif/hex file has been changed and the sof was being updated but the synthesis/p&r step was skipped. A full compile didn't have the case sensitive problem.
