21 years agoMemory footprint
What are the typical size ranges you can expect for the Kernal. How much working memory does it require. My feeling is 2Meg for the Kernal and 4 Meg total for RAM should do it. Does that seem r...
21 years agoHi mountain8848,
> what about the relationship about them(vmlinux and kernel)? > why not they are the same size? vmlinux is an elf file and it contains lots of extra linker sections like comments and debug information that are not allocated space in your memory. For example, my vmlinux size is about 11 MB, but the allocated memory (in the elf) is about 1.3 MB. You can get a better sense for the amount of memory your kernel code will occupy by stripping the elf: $ nios2-elf-strip vmlinux Or you can just use objdump and add up the sections that have the ALLOC attribute. But note that this does not account for any dynamic memory that may be needed. Regards, --Scott
