16 years agoMemory footprint
Hello, I am having problems getting my software to run and i believe the memory footprint is the issue. I keep getting the following error make: *** [../TestSTDIO_bsp-recurs-make-lib] Error 2...
16 years ago --- Quote Start --- Hello, I am having problems getting my software to run and i believe the memory footprint is the issue. I keep getting the following error make: *** [../TestSTDIO_bsp-recurs-make-lib] Error 2 Is there a way to see the exact memory footprint of a nios 2 application? If so where can I find this. --- Quote End --- Create a MAP file for the project: Project properties -> C/C++ Build -> Linker -> General -> Linker flags Add: -Wl,-Map,filename.map But I don't believe this is a memory image problem. I've seen these make errors for silly things like having a space in a file name that I forgot about (like when browsing in the IDE for a file and choosing a file that had a space). Bill
