16 years agoMemory Commands
Hi, im trying to use a SOPC-generated On-Chip-Memory (RAM) as a general purpose Data-Memory in my NIOS-System. What C-Functions can i use tio access the Memory? Is there a .h-File for the On-...
16 years agoHow do you access RAM in a standard micro controller? With a function? No. You just define some variables and the linker "places" these into the RAM. Since NIOS *is* a standard micro controller it's the same method here. Tell the linker to use your RAM as for the rwdata or the stack or the heap...
In case you already have a RAM for your variables and want to use an additional RAM you have to use pointers for reading and writing to the additional RAM, as Daixiwen said. Harald
