19 years agoMemory bits
Hi, I am using a cyclone 1 FPGA chip having about 290,000 memory bits. After I finished my design and while compilation with quartus, I get get an error printing the following message :"Error: ...
19 years agoHi,
First: Have enabled SignalTap? It needs memory bits in order to save the states. (It is a typical signal tap error) Second: I am not sure if you can combine memory blocks from several columns into one large chunk. I have never used cyc_I, so I am just guessing. g
