14 years agoMemory address problem related to create a custom instruction
Hello, I'm working to compile the application sample from Nios II Custom Instruction User Guide. I made the hardware setup and configuration with QSys without problem and I've programmed ...
14 years agoIf I correctly understand your question, you only need to add MOBILE_ to the template define in order to match the name of your ddr device:
# define MEMORY_DEVICE_SIZE MOBILE_DDR_SDRAM_SPAN
