21 years agoMemory -> DMA -> UART
Quartus 4.2 | NIOSII 1.1 | EP1S25 DSP-Board | Win2k Hi there, i got the DMA working with HAL to send data from memory to memory. My next wish is to send data from memory to the UART. My UA...
21 years agoint fdterm; // FILEDESCRIPTOR RETURNED BY OPEN
int i; // for for(); FILE * fpterm; // FILE pointer returned by fdopen int uart1_rxcount = 0; //counts received data from uart alt_u8 uart1_rxbuffer[5]; //stores received data from uart int pattern=0xF;//data to fill memory unsigned int *p = (unsigned int*)(0x00010000);//Startadress unsigned int *j = (unsigned int*)(0x00010100);//Destinationadress //DMA_BASE= 0x00020880 //UART_BASE = 0x00020820 int main(void) { //Write to memory something for (i=0; i<5; i++) { IOWR_32DIRECT(p/*+i*/, 0, pattern);//writes pattern from memory to memory+5 } //to open the uart-channel in read/write-modus // fdterm = open("/dev/uart1", O_RDWR | O_NONBLOCK | O_NOCTTY); // fpterm = fdopen(fdterm,"rw+"); // fprintf(fpterm,"UART1 STARTED\r\n"); // check initial output //printf("JTAG STARTED\r\n"); IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x0); // dma transfer disabled //Send some words IOWR_ALTERA_AVALON_DMA_STATUS(DMA_BASE, 0); IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_BASE, (int)p); //Pointer to memory IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_BASE, (int)j); //Pointer to your device IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_BASE, 4); //Sending words (1 word == 4 bytes) IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_BASE, 0x0CC); //See description of dma control register return 0; } This is the code which copies from p (memory) to j(memory). Why can´t i copy from p(memory) to j(uart)? I hope there is no huge thinking mistake http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif thanks for help!
