16 years agomemcpy, altera dma and tests...
Hi, i'm trying to modify the memcpy function to decrease cpu usage (100% currently), while copying a huge quantity of data. i'm actually using uClinux (nommu) with a nios2 on an 3c120 FPGA. ...
16 years agoThanks for your attention,
i've almost the same problem... Everything works fine in userspace application, but i don't manage to use my code into memcpy.c... May be because of parallels calls, i don't really understand in which context memcpy can be called... as actris say if someone know what i have to check/do to manage to copy data with the altera DMA in memcpy.c... Thank You.
