13 years agoMeasuring the dynamic power consumption of my C program
I am using a Cyclone III board with NiOS EDS v12.0. I have an image processing algorithm and I would like to measure the power consumption of this algorithm during its execution. I see that the "POWER DISPLAY" LCD display shows power values throughout the execution of the code. Can anyone help me with this - How do I record these values so that I can compute an average offline? Thanks, Nirmala1 Reply
Hi Nirmala,
First, is your power display working well ? If you want to record the power values, you should connect MAX II in your Qsys system. Thanks to the FSM bus (MAX II, Flash, SRAM), you can manage to read some registers of MAX II, particularly those of power datas. regards,
