10 years agoMCP2515 CANbus implementation in NIOS using alt_avalon_spi_command on 10M50DA
Hello, Straight off, I am a newbie to the FPGA game, but am (trying to) temporarily help fill a hole on our team. I have an Altera 10m50da, and am attempting to implement canbus communicat...
8 years agoHi, I have started to work on MCP25625, which is similar to your MCP2515. Were you able to get it to work for you with nios?
Thanks,- nitin1231 year ago
I'm currently working on interfacing the MCP2515 CAN controller with a Nios II processor via SPI. While I can observe SPI transactions on a logic analyzer, I'm not receiving any responses from the MCP2515.
Has anyone successfully interfaced the MCP2515 with a Nios II processor? If so, could you share insights or code snippets that might help identify what might be going wrong in my setup?
Any guidance or suggestions would be greatly appreciated.
Thank you!
- Yoda_Altera1 year ago
Hello nitin123,
Thank you for your question. I will check with internal Altera teams, and will respond back with an answer soon.
