21 years agomaximum ethernet speed
Hello! simple question: what are your experiences about the network speed with nios2 and lwip stack? my scenario: nios2 @ 75MHz lwip stack udp packages 1500 bytes (loop sending alway...
20 years ago --- Quote Start --- originally posted by revolt@Oct 1 2005, 07:09 AM i took a look at a 1000 mbit mac ip from morethanip. they use a 4 bit mii interface @ 25 mhz to transfer the data to the phy. so the interface has a limit from 12.5 mbyte/s. i think gigabit ethernet is not fast enough.
kind regards
revolt
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10087)
--- quote end ---
--- Quote End --- that would cap the datarate at 100 mbit exactly, so there wouldnt be a point in using a Gbit lan mac by the way, when you want to reach 600 mbit (or even 400) then the receiving end station will be a problem, since 600 mbit is 75 mb/s, there are very few non server system that can sustain this kind of speed, so even if you could get this with a nios or orther FPGA system, the receiving end will have one hell of a time taking the data in (most normal HDD's cant do sustained writes over 60 mb/s) by the way, revolt, you said you did the checksum in HW, i asume this is a function normally done by the lwip? like CRC?
