21 years agomaximum ethernet speed
Hello! simple question: what are your experiences about the network speed with nios2 and lwip stack? my scenario: nios2 @ 75MHz lwip stack udp packages 1500 bytes (loop sending alway...
20 years agoI wrote a little UDP Server (Windows) that measures the time for receiving a given amount of packets, e.g. 10000 UDP packets.
Parallel I used the Packetizer Ethernet Sniffer to check if the result is okay. <div class='quotetop'>QUOTE </div> --- Quote Start --- But the data could be written on the board??(in ram? in flash??) I mean that when packet arrive from ethernet how could you do ?store it?? or?? Could anyone give me the source code for understand?[/b] --- Quote End --- From which side are you talking? The NIOS II or PC side. In my case I have a NIOS II and a PC connected via a crossover ethernet cable. The NIOS II only sends data to the PC and never receives packets form the server, expect ARP packets.
