16 years agoMaximum ethernet speed available with NiosII + Linux
Hello, I plane to built a system with a niosII mmu and linux on an Cyclone III device. I will use an IP ethernet core with an dp83848 phy. I need to use ethernet TCP communication. What is t...
16 years agoSee my thread on this here: http://www.alteraforum.com/forum/showthread.php?t=18934
There's a link or two to other useful threads there too. So far ethernet performance with a gigabit PHY (DP83865) can best be described as disappointing. I haven't been able to get it to work correctly at gigabit speed, so my results should be comparable to the DP83848. I am getting at best 38Mbit/s UDP with 1KB messages and 30Mbit/s TCP with the following tweaks: - altera_tse.c (SLS) driver for the altera TSE MAC - 32KB processor caches - a bunch of network related kernel functions in SSRAM instead of DDR DRAM - no cache burst - MMU (similar results without it) I am also seeing some unexplained dropped packets. Note that at least one other person in the thread has been able to get hundreds of Mbit/s with a similar setup, though they weren't using Linux.
