max10 remote system update nios with uart
Hello aiedb,
Please check size of your generated file for CFM1.
In my case, factory_app1.map including Factory Image and Application 1 Image shows below.
BLOCK | START ADDRESS | END ADDRESS |
ICB | 0x00000000 | 0x00001FFF |
UFM | 0x00002000 | 0x00011FFF |
CFM0 | 0x000BA000 | 0x00161FFF |
CFM1 | 0x00012000 | 0x000B9FFF |
Start and end address of CMF 1 in the map file are 0x12000 and 0xB9FFF, respectively.
Therefor the size of CFM1 is 0xA8000 ( 0xB9FFF - 0x12000 + 1 ).
0xA8000 as decimal is 688128.
After generating pof and rpd, you can see the following files which are extracted of each block.
File | Size |
factory_app1_auto.rpd | 1449984 |
factory_app1_cfm0_auto.rpd | 688128 |
factory_app1_cfm1_auto.rpd | 688128 |
factory_app1_ufm_auto.rpd | 65536 |
The size of factory_app1_cfm1_auto.rpd should be same as 0xA8000(688128).
Yoshiaki
hii thanks now i have the version working for me
what i have found that i need to disable the small driver library in the bsp editor
and i need to enter the address in this form x12000 not 12000 in order for the program to work 'thanks for help a lot
- YoshiakiS_Altera1 year ago
Hello aiedb,
I'm glad to hear that.
If you face another issue, please open a new thread.
Yoshiaki
