aiedb
1 year agomax10 remote system update nios with uart
hii i have progressed with the example of doing max10 rsu over uart with nios i have the neek dev board for practicing i have added to the qsys system of the original project that i downloaded fr...
YoshiakiS_Altera
1 year agoHello aiedb,
You can use these files for the MAX10 NEEK KIT with no modification.
But the input clock is assumed 50MHz for OnChip.qys so that you should assign one of MAX10_CLK1/2/3_50 in NEEK to the clock.
Lastly, you need to create new pfl.sof for NEEK instead of master_image/pfl.sof for programming Nios_application.pof to QSPI memory on NEEK because pfl.sof depends on QSPI pin assignment on Max10.
Yoshiaki
- YoshiakiS_Altera1 year ago
Hello aiedb,
We have confirmed that the RSU demo design works fine on Max10 Dev Kits as below.
Let us know if you have any questions.
Yoshiaki
