max10 remote system update nios with uart
hii
i am trying to follow the application note to build a system to do a remote update of max10 over uart with nios 2
i built the qsys system with the on chip flash in order to store a factory and application rpd files
i attached the image of the on chip flash configuration i configured it as a dual compressed image in order for the cfm sections to be available to store the files
in the internal configuration under assignments-> device ->devices and pins -> configuration
i choose dual compress image the same as on chip flash configuration
also here i attached the image of my configuration
but when i compile the design i get this error
Current Internal Configuration mode does not support memory initialization or ROM.
Select Internal Configuration mode with ERAM
that does not make sense to me cause i am using dual compressed image , i be glad for help or to see if i made a mistake in my configurations
- sstrell
What's your target device? 10M02 does not support this (only has CFM0).
- FvM
I see that the target device is 10M50DA, thus it is supporting remote system upgrade with dual compressed image. But due to inherent limitation of MAX10 series, you can't have dual image and internal ROM at the same time. Respectively NIOS processor can be only booted from external SPI flash, see AN741.
Frank- sstrell
Ah, missed that on the error screenshot.
- BoonBengT_Altera
Moderator
Hi @aiedb,
As previous clarificcation has been attended, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
