15 years agoMax throughput of SOPC DMA?
Hello, Currently I have a system with DMA transfers and DDR2 SDRAM (and a lot of other stuff). I'm using the normal SOPC builder DMA controller. I run the system on 100 MHz, the DDR2 SDRAM run...
15 years agoYou definitley need to try to avoid the clock crossing and bus width adapters, they will both slow things down significantly.
This is all made more difficult because the sopc builder won't tell you where it has inserted them.
