aiedb's avatar
aiedb
3 years ago
max 10 neek udp client
hii
i want to do a udp client project
the max10_neek div board will be a udp_client that sends a message periodically to a pc (the pc will be a udp server ) , the pc will receive the message and send a reply to the udp client (max10 neek)
is there any example design that's gets me started ?
    • aiedb's avatar
      aiedb
      hii thanks for your reply
      i know this example and i activated it on my board
      its close but not enough
      i want to to send udp message from the max10 neek development board to the pc , for example
      "hello server , i am the client"
      and the pc will sent a reply to the max10 neek development board
      "hello client , i got you"
      the max 10 board will receive this message back from the server and toggles a led or display a number on the 7 sig . it doesn't matter
      this for indication that max10 board received a udp message .
      what i am looking to do is to build client-server relationship between the max10-neek and my pc using udp protocol
  • hareesh's avatar
    hareesh
    Sorry, Right now we have that example design only.
    i will request engineering team for this from my side, bit it takes some time.
  • aiedb's avatar
    aiedb
    THANKS I WILL BE GLAD TO GET FURTHER UPDATE
  • hareesh's avatar
    hareesh
    if you don't have any queries about this i will close this case. please conform it.
  • aiedb's avatar
    aiedb
    hii thanks
    you can close it
