DR123
6 years agoMAX 10 EMIF DDR3 low transfer rate
Hi, I’m working with a MAX 10 device (DECA development board) to transfer data from a FIFO to the DDR3. I’m using a Scatter Gather DMA and a EMIF DDR3 controller to transfer the data. The DMA works ...
Deshi_Intel
6 years agoHI,
To isolate your issue to find the bottleneck, you can start with small design first then only slowly add more design block into it.
For instance :
- Create DDR3 only design and test the performance
- Then upgrade to DDR3 + DMA design (without using QSYS)
- Then upgrade to DDR3 + DMA design (with using QSYS)
dlim
