16 years agomanualy uClinux without niosftp.com/pub/uclinux/ tar file
I am trying to build uClinux on my Neek board without a prebuilt binary tool chain. Actually, i followed the CrossGcc toturial on nios wiki and then i have downloaded uClinux-dist-20090618 from...
16 years agoOk thanks Michael, so
1 with MMU : what do you mean about building the complete Toolchain from scartch ? Would you mean that inside de mmu distribution there is a prebuilt binary toolchain ? (am i right with the terme ?) 2 without MMU : Ok so this is a pack containing all source file (binutils, c library, kernel header and the kernel uClinux). And the make script you mention is the one lacated in the $HOME/nios2-linux/toolchain-build as mention in the InstallNios2Linux instructions (make gcc elf2flt gdb-host) ?
