20 years agoManual ethernet settings
hallo ,
Does somebody know how to inintialize ethernet ,after making ethernet settings manuallly in ecos config tool. thanks, NIrav1 Reply
Hi nirav,
> Does somebody know how to inintialize ethernet First, you should review the description of the the configuration option for manual configuration (e.g. CYGHWR_NET_DRIVER_ETH0_MANUAL): [emphasis added]<div class='quotetop'>QUOTE </div> --- Quote Start --- If this option is selected, the eCos library provides no initialization code for this interface; you must perform all the initialization in the application, by means of appropriate ioctl() calls, or by calling init_net() with anappropriate bootp record you have constructed yourself.[/b] --- Quote End --- Second, use the force and review the following in the packages/net tree: -- sockio.h -- network_support.c -- bootp_support.c It should answer most of your questions. Regards, --Scott
