21 years agoManaging Design Components
Hello: This is as much a Quartus question as it is a NIOS question, but here it goes. I've created custom periferrals using Quartus. They exist as bdf files in one of my project direc...
21 years agoIf it is a NIOS periferal you build it into you system using Sopcbuilder using the create new Component function.
When this is done some directories are crerated ubder your project, the directory has the name of you periferal. You can copy this directory tree to any location on your network. In the SOPCbuilder setup you can choose the location for your own components, if this is placed on the network and you copy your periferal to this directory they are available to you colleagues, if they point to the same directory.
