10 years agoMaking Qsys Master Component
I was wondering if someone can send me a tutorial that indicates how to make an Avalon memory mapped master component in Qsys. Thanks,
10 years ago --- Quote Start --- I don't think there is any tutorial. Altera gives you some example/templates you can follow: https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-mm.html Beyond that, you're largely on your own. To save yourself some grief, I would recommend familiarizing yourself with the Avalon Verification IP and take the time to construct a good testbench. https://www.altera.com/support/support-resources/design-examples/design-software/simulation/exm-avalon-verification-ip.html Depending on what you are trying to accomplish, the Modular SGDMA is another good resource to extend/borrow from: http://www.alterawiki.com/wiki/modular_sgdma --- Quote End --- Thanks, I designed it. Actually it was quite easy.
