14 years agomaking an IP for DMA transfers
Hello everybody. I work with the Terasic DE2-115. I'm trying to plug the TRDB-D5M camera on a NIOS II with ethernet. I can read data from the camera with the IP given by terasic, and I can us...
14 years agoThat's correct, the mSGDMA uses streaming as well so the ST port of the write master can be used for this sort of thing as well.
I would make sure you have the latest version of the mSGDMA if you use it in your design, you can find it here: http://www.alterawiki.com/wiki/modular_sgdma I'll be updating it soon with a couple of small enhancements and a bug fix for packet ST-->MM transfers.
