16 years agoMakefile ROMFS with subfolders
Is there a way to modify the location of the files in the vendors folder? i have differnt Image configurations and i want to make sub folders so that i don't lose the overview. something like...
16 years ago$(SUB_FOLDER) is just a variable in the makefile. Using the working structure above, in the makefile:
SUB_FOLDER = "../../Altera/nios2/sub-folder/application" ... $(ROMFSINST) $(SUB_FOLDER) /home/application However, this is a much different method than the one proposed by mschnell. The symlink is not 'in' the makefile. Basically, you set up the structure that you want in the file system, and you create a symbolic link from 'their' folder to 'yours'. That way you don't mess with their structure (could give you a big headache later if you don't document the changes properly). Although your method might work, I wouldn't mess around too much with the Makefile...
