21 years agoMakefile for simple linux device driver
Hello everyone, i'm trying to write a device driver. It is an external driver. It should be load with insmod in an running system. My problem is, that i cannot build the module (I sta...
21 years agoThank you very much for your quick reply, Ken.
Unfortunately it doesn't work. Maybe it's good idea to sum up, what i did so far: 1) I created a kernel project, with this external module loading/unloading support enabled: the project directory with the compiled and build files is located at: -> d:\MyKernel 2) I made a Linux Filesystem of course 3) To create module project, i used "Linux Application". It is located in: -> d:\MyModule The name of .c file is MyModule.c i do not use the settings und rules files. its just to have project in my workspace. 5) a lot different makefiles 4) I tried your suggested makefile, but it doesn't work. I get a syntax error about the "-O" so i deleted the "-O" option, and tried again. Now I get following error: make all make -C M='pwd' O=/cygdrive/d/MyKernel/build all make: *** M=pwd: No such file or directory. Stop. make: *** [all] Error 2 -- Thanks a lot.
