19 years agoMake romfs, errors????????
Hi all. when i make command(build kernel binarytoolchain with board 1c12 on linux): make romfs ===>some results: er@localhost uClinux-dist]$ make romfs ............... echo "Alter...
19 years agomake menuconfig
check if you have the correct target? Altera, nios2nommu, and Libc must be None. Vendor/Product Selection ---> --- Select the Vendor you wish to target (Altera) Vendor --- Select the Product you wish to target (nios2nommu) Altera Products Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> DO NOT change any other setting until first successful boot.
