13 years agomake menuconfig fails with 20120802-tarball
Hello, after I got the DE0-nano up and running the last days with the linux-tarball from 2009 I want to switch to the actual branch and my custom board. For this I downloaded and "instal...
13 years agoHi all,
Very helpful thread. I, however, got stuck with the part when it was said "compile 'mconf' with my 32-bit ubuntu". I found that by just removing the compiled file "mconf" and then running "make menuconfig" as usual worked as well - the file gets generated through the "make menuconfig" process so no need to try and cross-compile manually. This could be obvious to you guys but it might help other beginners like myself. Thanks for the support.
