13 years agomake menuconfig fails with 20120802-tarball
Hello, after I got the DE0-nano up and running the last days with the linux-tarball from 2009 I want to switch to the actual branch and my custom board. For this I downloaded and "instal...
13 years agoHi dsl,
thank you very much for your helpfully direction. You are right, 'mconf' can't be executed directly. Here's my output of the file analysis:
guinea@guinea-VirtualBox:~/Dev/uClinux/nios2-linux/uClinux-dist$ file /home/guinea/Dev/uClinux/nios2-linux/uClinux-dist/config/kconfig/mconf
/home/guinea/Dev/uClinux/nios2-linux/uClinux-dist/config/kconfig/mconf: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, not stripped
guinea@guinea-VirtualBox:~/Dev/uClinux/nios2-linux/uClinux-dist$ ldd /home/guinea/Dev/uClinux/nios2-linux/uClinux-dist/config/kconfig/mconf
not a dynamic executable
guinea@guinea-VirtualBox:~/Dev/uClinux/nios2-linux/uClinux-dist$ objdump -p /home/guinea/Dev/uClinux/nios2-linux/uClinux-dist/config/kconfig/mconf
/home/guinea/Dev/uClinux/nios2-linux/uClinux-dist/config/kconfig/mconf: file format elf64-x86-64
Program Header:
PHDR off 0x0000000000000040 vaddr 0x0000000000400040 paddr 0x0000000000400040 align 2**3
filesz 0x00000000000001c0 memsz 0x00000000000001c0 flags r-x
INTERP off 0x0000000000000200 vaddr 0x0000000000400200 paddr 0x0000000000400200 align 2**0
filesz 0x000000000000001c memsz 0x000000000000001c flags r--
LOAD off 0x0000000000000000 vaddr 0x0000000000400000 paddr 0x0000000000400000 align 2**21
filesz 0x000000000001e2cc memsz 0x000000000001e2cc flags r-x
LOAD off 0x000000000001e2d0 vaddr 0x000000000061e2d0 paddr 0x000000000061e2d0 align 2**21
filesz 0x0000000000001cf0 memsz 0x0000000000005198 flags rw-
DYNAMIC off 0x000000000001e2f8 vaddr 0x000000000061e2f8 paddr 0x000000000061e2f8 align 2**3
filesz 0x00000000000001b0 memsz 0x00000000000001b0 flags rw-
NOTE off 0x000000000000021c vaddr 0x000000000040021c paddr 0x000000000040021c align 2**2
filesz 0x0000000000000044 memsz 0x0000000000000044 flags r--
EH_FRAME off 0x000000000001b9dc vaddr 0x000000000041b9dc paddr 0x000000000041b9dc align 2**2
filesz 0x0000000000000804 memsz 0x0000000000000804 flags r--
STACK off 0x0000000000000000 vaddr 0x0000000000000000 paddr 0x0000000000000000 align 2**3
filesz 0x0000000000000000 memsz 0x0000000000000000 flags rw-
Dynamic Section:
NEEDED libncursesw.so.5
NEEDED libtinfo.so.5
NEEDED libc.so.6
INIT 0x0000000000401b78
FINI 0x0000000000415ef8
GNU_HASH 0x0000000000400260
STRTAB 0x0000000000400d10
SYMTAB 0x00000000004002c0
STRSZ 0x0000000000000391
SYMENT 0x0000000000000018
DEBUG 0x0000000000000000
PLTGOT 0x000000000061e4b8
PLTRELSZ 0x00000000000008e8
PLTREL 0x0000000000000007
JMPREL 0x0000000000401290
RELA 0x00000000004011d0
RELASZ 0x00000000000000c0
RELAENT 0x0000000000000018
VERNEED 0x0000000000401180
VERNEEDNUM 0x0000000000000001
VERSYM 0x00000000004010a2
Version References:
required from libc.so.6:
0x0d696913 0x00 05 GLIBC_2.3
0x09691974 0x00 04 GLIBC_2.3.4
0x06969194 0x00 03 GLIBC_2.14
0x09691a75 0x00 02 GLIBC_2.2.5
After recompiling the 'mconf' with my 32-bit ubuntu I can successfully execute 'make menuconfig' :) Let's see what surprises will next upcome ... Greetings guinea @Altera P.S.: Perhaps it is a good idea to update the instructions at "alterawiki.com/wiki/Install_Nios_II_Linux"
