19 years agomake menuconfig error
I use BinaryToolchain for building kernel as the saying at http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain). But when i check the 'cc',these happened:
[root@www bin]# cc bash: cc: command not found then i go on: [nios@www uClinux-dist]$ su Password: [root@www /]# cd /usr/bin [root@www bin]# ln -s gcc cc [root@www bin]# cc -v bash: cc: command not found I don't know why? Then,when i run make menuconfig: these errors happened: [nios@www uClinux-dist]$ make menuconfig config/mkconfig > config.in make -C /home/nios/download/uClinux-dist/config/scripts/lxdialog all make[1]: Entering directory `/home/nios/download/uClinux-dist/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] 错误 1 make[1]: Leaving directory `/home/nios/download/uClinux-dist/config/scripts/lxdialog' make: *** [menuconfig] 错误 2 How i can solve that? Thank you !!!1 Reply
Which Linux distro do you use?
You will need gcc and ncurses devel packages.
