17 years ago
make linux image error
I am trying to customize my own uClinux kernel and create a zImage to be run on the Altera DE2 board. However, after I run "make vendor_hwselect SYSPTF=...", I then type make to compile the kernel and apps, and it quits with an error as seen in the last six lines below. These lines were copied directly from the Ubuntu terminal I am working in. Any help on this issue is greatly appreciated.
phil@ubuntu:~/Desktop/uClinux-dist$ make
make -C tools/ucfront
make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/tools/ucfront'
cc -g -Werror -Wall -DHAVE_MKSTEMP -o ucfront ucfront.c args.c util.c execute.c
cc -g -Werror -Wall -DHAVE_MKSTEMP -o ucfront-ld ucfront-ld.c args.c util.c execute.c
cc -o jlibtool jlibtool.c
make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/tools/ucfront'
ln -sf /home/phil/Desktop/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/phil/Desktop/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/phil/Desktop/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld
ln -sf /home/phil/Desktop/uClinux-dist/tools/ucfront/jlibtool tools/jlibtool
make -C tools/sg-cksum
make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/tools/sg-cksum'
cc -Werror -Wall -DHAVE_MKSTEMP -o cksum cksum.c crc.c print.c sum1.c sum2.c crc32.c
make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/tools/sg-cksum'
ln -sf /home/phil/Desktop/uClinux-dist/tools/sg-cksum/cksum tools/cksum
chmod +x tools/romfs-inst.sh tools/modules-alias.sh tools/build-udev-perms.sh
make -C config automake
make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/config'
make[1]: Nothing to be done for `automake'.
make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/config'
. linux-2.6.x/.config; if [ "$CONFIG_INITRAMFS_SOURCE" != "" ]; then
mkdir -p `dirname $CONFIG_INITRAMFS_SOURCE`;
touch $CONFIG_INITRAMFS_SOURCE || exit 1;
fi
dirname: extra operand `../vendors/altera/nios2nommu/romfs_list'
try `dirname --help' for more information.
mkdir: missing operand
try `mkdir --help' for more information.
touch: cannot touch `../vendors/altera/nios2nommu/romfs_list': no such file or directory
make: *** [linux] error 1
    <div class='quotetop'>QUOTE (ppitou @ Jul 9 2009, 05:38 PM) <{post_snapback}> (index.php?act=findpost&pid=23053)</div>
    --- Quote Start ---
    You are "making" from the wrong directory. check your install but you should "make" under /nios2-linux/uClinux-dist
    go back and follow http://www.nioswiki.com/installnios2linux (http://www.nioswiki.com/installnios2linux)[/b]
    --- Quote End ---
    ok thanks for the reply .. however i used http://www.nioswiki.com/operatingsystems/u...binarytoolchain (http://www.nioswiki.com/operatingsystems/uclinux/binarytoolchain) instead of what you posted because on the uClinux page it says "2. Install Nios2Linux install the source and build tools. Or you can use prebuild BinaryToolchain ." and i chose the later rather then the former .. should i just restart fresh from the link you posted .. or is there a way to fix it using the prebuilt binary toolchain? thanks
    <div class='quotetop'>QUOTE (TwistedNRG @ Jul 9 2009, 06:20 PM) <{post_snapback}> (index.php?act=findpost&pid=23054)</div>
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    [/b]
    --- Quote End ---
    ok ignore what i said above .. i should have still done those few steps before hand ..
    when i put this into my terminal "gettext ccache zlib1g-dev libx11-dev texinfo liblzo2-dev" i get an error saying gettext too many arguments .. any idea on that?
    all errors have been fixed .. no need to reply anymore .. thanks for the help
    /end thread
    --- Quote Start ---
    make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/tools/ucfront&#39;
    make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/tools/ucfront&#39;
    make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/tools/sg-cksum&#39;
    make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/tools/sg-cksum&#39;
    make[1]: Entering directory `/home/phil/Desktop/uClinux-dist/config&#39;
    make[1]: Nothing to be done for `automake&#39;.
    make[1]: Leaving directory `/home/phil/Desktop/uClinux-dist/config&#39;
    fi
    dirname: extra operand `../vendors/altera/nios2nommu/romfs_list&#39;
    try `dirname --help&#39; for more information.
    try `mkdir --help&#39; for more information.
    touch: cannot touch `../vendors/altera/nios2nommu/romfs_list&#39;: no such file or directory
    --- Quote End ---
    How you resolved it? I encounter the same question too!
