17 years agomake linux image error
I am trying to customize my own uClinux kernel and create a zImage to be run on the Altera DE2 board. However, after I run "make vendor_hwselect SYSPTF=...", I then type make to compile the kernel an...
17 years agoYou are "making" from the wrong directory. check your install but you should "make" under /nios2-linux/uClinux-dist
go back and follow http://www.nioswiki.com/installnios2linux (http://www.nioswiki.com/installnios2linux)
