20 years agoMake Failed!
Hello everyone,
In Step 3, [oneuser@RJ uClinux-dist-test]$make make: *** Warning: File `.config' has modification time in the future (2006-07-26 17:13:48 > 2006-07-26 17:11:10.095802) make -C tools/ucfront make[1]: Entering directory `/mnt/hgfs/share/uClinux-dist-test/tools/ucfront' cc -g -Werror -Wall -DHAVE_MKSTEMP -o ucfront ucfront.c args.c util.c execute.c cc -g -Werror -Wall -DHAVE_MKSTEMP -o ucfront-ld ucfront-ld.c args.c util.c execute.c make[1]: Leaving directory `/mnt/hgfs/share/uClinux-dist-test/tools/ucfront' ln -sf /mnt/hgfs/share/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc ln: 正在创建连至‘/mnt/hgfs/share/uClinux-dist-test/tools/ucfront/ucfront’的符号链接‘tools/ucfront-gcc’: 不允许的操作 Pls give me you advice,thanks!!2 Replies
you have to install uClinux-dist-test on a linux home dir, eg, /home/hippo .
it can not be on a windows shared drive. - Altera_Forum
Thank you rery much!
