16 years agomake error!!!
make menuconfig make //custom fpga MODPOST vmlinux.o WARNING: modpost: Found 4 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISM...
16 years agoyou are looking in the wrong directory..
look under /nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/kernel and find file vmlinux.lds change comments from //#define ... to /*#define ... */ I had about 7 lines to change around line 302 and it solved the problem.
