16 years agomake error!!!
make menuconfig make //custom fpga MODPOST vmlinux.o WARNING: modpost: Found 4 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISM...
16 years agoi have the same problem:
WARNING: modpost: Found 4 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 /home/emil_kruki/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:192: syntax error make[2]: *** [.tmp_vmlinux1] Fehler 1 make[1]: *** [sub-make] Fehler 2 make[1]: Leaving directory `/home/emil_kruki/nios2-linux/linux-2.6' make: *** [linux] Fehler 1 emil_kruki@hws-162:~/nios2-linux/uClinux-dist> but there are only 130 lines in vmlinux.lds.S, and in file vmlinux.lds.h i can not recognize an syntax error....
