16 years ago
make error when "Enable Loadable Module Support"
I'm using the Cyclone Development Board
With my custom *.ptf and *.sof I can get the Compact Flash up and working (ext3 format).
When I try and enable loadable module support I get the following.
CC net/sunrpc/stats.o
LD net/ipv4/built-in.o
LD net/sunrpc/sunrpc.o
LD net/sunrpc/built-in.o
LD net/built-in.o
LD vmlinux.o
MODPOST vmlinux.o
WARNING: modpost: Found 2 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
GEN .version
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
LD init/built-in.o
LD vmlinux
__pata_platform_remove: discarded in section `.devexit.text' from drivers/built-in.o
make[2]: *** [vmlinux] Error 1
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/janet/nios2-linux/linux-2.6'
make: *** [linux] Error 1
[janet@localhost uClinux-dist]$
When I do the "make CONFIG_DEBUG_SECTION_MISMATCH=y" I get:
CC fs/mbcache.o
LD fs/built-in.o
LD vmlinux.o
MODPOST vmlinux.o
WARNING: vmlinux.o(.text+0xe0): Section mismatch in reference from the variable data_flush to the function .init.text:start_kernel()
The function data_flush() references
the function __init start_kernel().
This is often because data_flush lacks a __init
annotation or the annotation of start_kernel is wrong.
WARNING: vmlinux.o(.text+0xe4): Section mismatch in reference from the variable data_flush to the function .init.text:start_kernel()
GEN .version
CC init/version.o
LD init/built-in.o
LD vmlinux
But I have NO CLUE what this is telling me.
Any advice would be appreciated.
I'm using this board before I get our custom board and having loadable module support is pretty darn important when you are developing a device driver.
    After more trial and error it seems to be related to the
    __pata_platform_
    That I need for SCSI according to the Wiki Compact Flash.
    Any ideas ?
    Thanks in advance
    I got things working by changing my Compact Flash configuration to use the
    Serial ATA -->
    [*] Altera SOPC Builder CompactFlash Support (EXPERIMENTAL)
    INSTEAD OF THE - wiki page
    [ ] Generic Platform Device PATA support
    So, should there be any problems with that.
    It seem to be working fine. Any known problems with this EXPERIMENTAL stuff?
