22 years agomake clean, make mrproper
It appears as if you can only build your kernel once, I need to enable module unloading in the kernel and when I try to build the kernel I get a "..kernel-2.6.x is not clean, please run 'make mrp...
22 years agoThat's what I meant, when it worked orignally I'd used your PTF, but this time after reinstalling I'd used alteras PTF which is why it didn't work. However, when loading a sof to the board I was always using alteras which is where I seemed to lose the plot.
I'm all out of questions for the moment! Try rmmod - it now "works" except it causes a reset, that could be because I was lazy and didn't recompile my module. I'll try recompiling and take it from there.
