22 years agomake clean, make mrproper
It appears as if you can only build your kernel once, I need to enable module unloading in the kernel and when I try to build the kernel I get a "..kernel-2.6.x is not clean, please run 'make mrp...
22 years agoIt sounds like you might be looking at it the other way around. I think you might have supplied the PTF file for the standard 1c20 project to your kernel since that target hardware doesn't include a compact flash interface.
Our next release will provide a property page for kernel projects that will allow you to see which ptf file the project is associated with. In the meantime, you can check manually by looking at the STF file in the project. And please, keep the questions coming if you've got 'em. Ken.
