16 years agomacro for detecting OS presence
I am writing a driver for my 1-wire (onewire) master RTL, and I would like to write the driver so that it would with or without the OS. But the ISR implementation depends on the availability of flags and semaphores. Is there a macro I could check to switch between two ISR implementations, something like:# ifdef UCOSII
// ISR implementation using flags and semaphores# else
// ISR implementation using global volatile variables and polling# endif
Regards, Iztok Jeras3 Replies
If you use Nios IDE 9.0sp2 you can simply use:
# ifdef UCOS_II ... I don't know the same define applies to other tools versions, too. Cris - Altera_Forum
I opened the source of the OpenCores eth_ocm components and it seems there is a macro named UCOS_II, I will try it and see.
I compiled the uCOS-II hello world and tested for the presence of UCOS_II, and I was not able to find it. So it seems there is no such macro in version 9.1sp2 of the Nios II EDS. I implemented the code differently.
Iztok Jeras
