20 years agoMAC-address
I am working with a nios development board with a stratixII_2s60. When I start ethernet communication the console shows "Can't read MAC address." For the development boards with a 1S40 device and earlier development kits the MAC address is stored at 0x7f000 in flash. Does anyone have an idea what this should be for the nios development board with a stratixII_2s60 ? Thanks.5 Replies
How if ThomsonBro == true....
Hi ThomsonBro, I never had any problems because it couldn't read the MAC Address.... Like I told you: it appears to be a 32-bit large integer. I believe the flash memory is connected 16 bit wide... is it possible to read a 32-bit number in that way?! Good luck with your assignment... Cheers, Danny - Altera_Forum
All right, thanks Danny http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif . But now I’ve a different problem.
I run the lwip_web_server example form the forum (lwip-v1_1.zip) and I have already done what is written in the readme file. When I tried to ping, I got a reply. But when I go to the board with the browser http:// ip addr it won’t work. The IDE shows this error: [Conflicting names: /cygdrive/c/altera/kits/nios2_51/components/altera_avalon_lan91c111/HAL/src/altera_avalon_lan91c111.c ] warning: use of cast expressions as lvalues is deprecated [/cygdrive/c/altera/kits/nios2_51/components/altera_avalon_lan91c111/HAL/src/altera_avalon_lan91c111.c ] lwip_web_server_0_syslib line 894 This error is 22 times displayed and all of them are located in the file altera_avalon_lan91c111.c I cannot edit this file. Does anyone have an idea how to solve these errors? Thanks a lot. - Altera_Forum
TB,
Don't waste your time trying to fix these warnings. The fact that pinging your IP address works, means that your stack is functional. You need to set some breaks in the web_server code to determine where things are failing. Best Regards, - slacker - Altera_Forum
Hi Slacker,
I have put a breakpoint at the first line where things went wrong. (line 741 of altera_avlon_lan91c111.c) After building the source I got zero errors and warnings. Nice, cause still without the expected result. It is impossible to reach the ram from the http. It seems like some important parts of the source are not running now. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Cheers. - Altera_Forum
Well, problem is solved now. My proxy settings in internet explorer set wrong and when I changed them I still got the same problem. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
With firefox it will work. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thanks to all, cheers --- Quote Start --- originally posted by thomsonbro@Feb 17 2006, 05:41 AM hi slacker,i have put a breakpoint at the first line where things went wrong. (line 741 of altera_avlon_lan91c111.c)
after building the source i got zero errors and warnings. nice, cause still without the expected result. it is impossible to reach the ram from the http.
it seems like some important parts of the source are not running now. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/wink.gif
cheers.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12766)
--- quote end ---
--- Quote End ---
