16 years agom_state == STATE_DEBUG Error
I build a SOPC system which consists of a Nios II cpu, onchip memory and jtag uart component with frequency of 100MHz driving all the components. The system works fine when I run the count binary pro...
14 years agoI was having same issue...and two potential causes for this are a) Burst not enabled in the CPU for Instruction and Data master b) USB blaster connection...in my case it was (a)....also be careful while enabling the burst for data master if you are using a 16 bit flash (no byte mode)...hope this helps :)
