16 years agom_state == STATE_DEBUG Error
I build a SOPC system which consists of a Nios II cpu, onchip memory and jtag uart component with frequency of 100MHz driving all the components. The system works fine when I run the count binary pro...
15 years agoIf you have room for a small on-chip memory then I recommend making a small memory test program that can fit into it to test your external memory. There are templates for "memtest" and "memtest_small" that you can take a look at (maybe memtest_small will fit in your on-chip RAM).
