16 years agom_state == STATE_DEBUG Error
I build a SOPC system which consists of a Nios II cpu, onchip memory and jtag uart component with frequency of 100MHz driving all the components. The system works fine when I run the count binary pro...
15 years agoThat could be due to the timing problem on your memory component. Suggest you to check the memory timing.
