21 years agoLWIP/LAN91C111 Bug!
I've just spent the best part of a day trying to get some simple socket stuff to work under LWIP/uCos. Symptoms? Telnet-style connections locked up and dropped mysteriously... Anyway, ...
21 years agoI've taken the SSS example and tweaked it to handle file transfers. In my test the board receives a file in 1500 byte max data packets and immediatly sends them back to the client. There are several things I could do to streamline the code, I just didn't expect it would be so slow. The NiosII is tiny model (no cache) @ 30Mhz. The lan91C111 has a 16bit bus. Have to give ethereal a try if I run out of ideas.
