20 years agolwip-v1_1 supporting IDE ver 5.1
Hi, I would like to know if the LwIP distribution found on the Nios-Forum Supports IDE ver 5.1. Elad B
20 years ago --- Quote Start --- originally posted by eladba@Jan 2 2006, 10:45 AM hi,
i would like to know if the lwip distribution found on the nios-forum
supports ide ver 5.1.
elad b
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11886)
--- quote end ---
--- Quote End --- I tryed to use lwip ver 1.1 under NIOS II ver 5.1 but i have encountered a problem. The Ethernet does not start if the ethernet cable is plugged in the RJ45 connector at the startup or after a software reset. I have to wait that the software starts before to connect the cable. after doing so the ethernet controller starts to work in normal mode. This problem does not exist with the MICRO C OS II. I'm wandering for solutions.....http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif bye shadowice
