21 years agolwIP UDP thoughut w/o an RTOS
Wanted to receive 1500 byte payload from 100 MAC (on Cyclone II) device, and using lwIP UDP no RTOS is required. Can the UDP RX receive 80 Mbit/s? Where the UDP TX is minimal for data flow cont...
20 years agoHi @ all,
well it seems that I've lost my code, but it is not that hard to accomplish it. What I did mostly (because it was possible) is to clock the NIOS @ 135 MHz, use max datacache and instructioncache. Furthermore I used the UDP-feature of the lwip-stack. Good luck. Cheers, Danny
