21 years agoLWIP standalong server bug?
Examining the example lwip_server, in particular httpd.c. When tcp_close is called the pcb is deallocated, so surely a tcp_new,bind must be performed again? in the LWIP source tcp.c you can see the memp_free? is there any good documentation for the LWIP rawapi, the little rawapi.txt file does not talk about pbuf management - such as is done within http_recv() for example? is the pbuf_free() necessary? and should the tcp_recved(pcb, p->tot_len) not actually be tcp_recved(pcb,p->len) ? tot_len is the sze of the buffer and all other chained ones? (or so the LWIP source comments say?) Are there any other examples of LWIP rawapi apps? Thanks! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Thanks!1 Reply
I'm also trying to use the standalone LwIP Raw API in a more extensive application than the http-server example.
I share the complaint that you made : the 'rawapi.txt ' documentation is far from complete. But to be maybe of a little help to you : the thesis written by Adam Dunkels (the original designer of LwIP) is available on the internet. in Chapter 4 it discusses in general how the TCP/IP stack works and you can find some more details about memory management and the use of the pbufs. You can find the thesis at http://www.sics.se/~adam/thesis.pdf (http://www.sics.se/~adam/thesis.pdf) I hope this answers some questions...
